Time Before: 0.00195 seconds
Time After: 0.00254 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00262 seconds
Time After: 0.00315 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00342 seconds
Time After: 0.00363 seconds
Time Before: 0.00450 seconds
Time After: 0.00881 seconds
Time Taken: 0.00431 seconds
Time Before: 0.00371 seconds
Time After: 0.01237 seconds
Time Taken: 0.00866 seconds
Time Before: 0.01452 seconds
Time After: 0.01496 seconds
Time Before: 0.01754 seconds
Time After: 0.01882 seconds
Time Before: 0.01374 seconds
Time After: 0.01908 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02480 seconds
Time After: 0.02496 seconds
Time Before: 0.02725 seconds
Time After: 0.02853 seconds
Time Before: 0.03187 seconds
Time After: 0.03204 seconds
Time Before: 0.03443 seconds
Time After: 0.03598 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1784718352, location = '/forums/private.php?do=newpm&explain=1&u=46487' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05322 seconds
Time After: 0.05354 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
