Time Before: 0.01663 seconds
Time After: 0.02296 seconds
Time Taken: 0.00634 seconds
Time Before: 0.02307 seconds
Time After: 0.02358 seconds
Time Before: 0.02384 seconds
Time After: 0.02399 seconds
Time Before: 0.02478 seconds
Time After: 0.02758 seconds
Time Taken: 0.00279 seconds
Time Before: 0.02406 seconds
Time After: 0.03251 seconds
Time Taken: 0.00846 seconds
Time Before: 0.04076 seconds
Time After: 0.04116 seconds
Time Before: 0.04386 seconds
Time After: 0.04510 seconds
Time Before: 0.04010 seconds
Time After: 0.04530 seconds
Time Taken: 0.00521 seconds
Time Before: 0.06861 seconds
Time After: 0.06875 seconds
Time Before: 0.08963 seconds
Time After: 0.09086 seconds
Time Before: 0.10470 seconds
Time After: 0.10493 seconds
Time Before: 0.10775 seconds
Time After: 0.10969 seconds
Time Taken: 0.00195 seconds
UPDATE session SET lastactivity = 1789128242, location = '/forums/private.php?do=newpm&explain=1&u=46488' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.13191 seconds
Time After: 0.13242 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
