Time Before: 0.00371 seconds
Time After: 0.00495 seconds
Time Before: 0.00505 seconds
Time After: 0.00607 seconds
Time Taken: 0.00102 seconds
Time Before: 0.00636 seconds
Time After: 0.00649 seconds
Time Before: 0.00742 seconds
Time After: 0.01002 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00656 seconds
Time After: 0.01455 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01784 seconds
Time After: 0.01837 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02140 seconds
Time After: 0.02276 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01712 seconds
Time After: 0.02300 seconds
Time Taken: 0.00589 seconds
Time Before: 0.03378 seconds
Time After: 0.03393 seconds
Time Before: 0.03690 seconds
Time After: 0.03817 seconds
End call of global.php: 0.039850950241089
Time Before: 0.04230 seconds
Time After: 0.04249 seconds
Time Before: 0.04464 seconds
Time After: 0.04622 seconds
Time Taken: 0.00158 seconds
SET lastactivity = 1783258451, location = '/forums/private.php?do=newpm&explain=1&u=46590'
Time Before: 0.06000 seconds
Time After: 0.06053 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.058823823928833 seconds with 9 queries, spending 0.0093626976013184 doing MySQL queries and 0.049461126327515 doing PHP things.
