Time Before: 0.00238 seconds
Time After: 0.00354 seconds
Time Taken: 0.00116 seconds
Time Before: 0.00361 seconds
Time After: 0.00418 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00438 seconds
Time After: 0.00452 seconds
Time Before: 0.00529 seconds
Time After: 0.00754 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00457 seconds
Time After: 0.01242 seconds
Time Taken: 0.00785 seconds
Time Before: 0.01501 seconds
Time After: 0.01537 seconds
Time Before: 0.01822 seconds
Time After: 0.01938 seconds
Time Before: 0.01442 seconds
Time After: 0.01958 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02500 seconds
Time After: 0.02514 seconds
Time Before: 0.02931 seconds
Time After: 0.03061 seconds
Time Before: 0.03492 seconds
Time After: 0.03506 seconds
Time Before: 0.03720 seconds
Time After: 0.03861 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=46681' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05159 seconds
Time After: 0.05193 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
