Time Before: 0.01909 seconds
Time After: 0.02699 seconds
Time Taken: 0.00790 seconds
Time Before: 0.02710 seconds
Time After: 0.02898 seconds
Time Taken: 0.00188 seconds
Time Before: 0.02947 seconds
Time After: 0.02975 seconds
Time Before: 0.03061 seconds
Time After: 0.03277 seconds
Time Taken: 0.00216 seconds
Time Before: 0.02984 seconds
Time After: 0.03696 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04841 seconds
Time After: 0.04899 seconds
Time Taken: 0.00058 seconds
Time Before: 0.05251 seconds
Time After: 0.05387 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04753 seconds
Time After: 0.05408 seconds
Time Taken: 0.00655 seconds
Memory After: 2,261.719 KB
Time Before: 0.08551 seconds
Time After: 0.08566 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10922 seconds
Time After: 0.11158 seconds
Time Taken: 0.00237 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.12056 seconds
Time After: 0.12073 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12399 seconds
Time After: 0.12546 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=46712', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14504 seconds
Time After: 0.14532 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
