Time Before: 0.01289 seconds
Time After: 0.02281 seconds
Time Taken: 0.00992 seconds
Time Before: 0.02294 seconds
Time After: 0.02381 seconds
Time Taken: 0.00087 seconds
Time Before: 0.02424 seconds
Time After: 0.02462 seconds
Time Before: 0.02530 seconds
Time After: 0.02722 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02467 seconds
Time After: 0.03158 seconds
Time Taken: 0.00691 seconds
Time Before: 0.04190 seconds
Time After: 0.04228 seconds
Time Before: 0.04496 seconds
Time After: 0.04621 seconds
Time Before: 0.04120 seconds
Time After: 0.04644 seconds
Time Taken: 0.00524 seconds
Time Before: 0.06389 seconds
Time After: 0.06411 seconds
Time Before: 0.39131 seconds
Time After: 0.39274 seconds
Time Before: 0.40578 seconds
Time After: 0.40594 seconds
Time Before: 0.40848 seconds
Time After: 0.40993 seconds
UPDATE session SET lastactivity = 1789038925, location = '/forums/private.php?do=newpm&explain=1&u=46735', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.43258 seconds
Time After: 0.43282 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
