Time Before: 0.01110 seconds
Time After: 0.01348 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01356 seconds
Time After: 0.01403 seconds
Time Before: 0.01429 seconds
Time After: 0.01440 seconds
Time Before: 0.01532 seconds
Time After: 0.01767 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01447 seconds
Time After: 0.02160 seconds
Time Taken: 0.00713 seconds
Time Before: 0.02624 seconds
Time After: 0.02663 seconds
Time Before: 0.02894 seconds
Time After: 0.03019 seconds
Time Before: 0.02553 seconds
Time After: 0.03038 seconds
Time Taken: 0.00485 seconds
Time Before: 0.04751 seconds
Time After: 0.04765 seconds
Time Before: 0.05390 seconds
Time After: 0.05514 seconds
End call of global.php: 0.057371139526367
Time Before: 0.06145 seconds
Time After: 0.06159 seconds
Time Before: 0.06360 seconds
Time After: 0.06503 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=46867'
Time Before: 0.07982 seconds
Time After: 0.08010 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.078907012939453 seconds with 9 queries, spending 0.0078051090240479 doing MySQL queries and 0.071101903915405 doing PHP things.
