Time Before: 0.01494 seconds
Time After: 0.02015 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02024 seconds
Time After: 0.02126 seconds
Time Taken: 0.00102 seconds
Time Before: 0.02159 seconds
Time After: 0.02173 seconds
Time Before: 0.02292 seconds
Time After: 0.02650 seconds
Time Taken: 0.00358 seconds
Time Before: 0.02179 seconds
Time After: 0.03084 seconds
Time Taken: 0.00905 seconds
Time Before: 0.03573 seconds
Time After: 0.03614 seconds
Time Before: 0.03840 seconds
Time After: 0.04055 seconds
Time Taken: 0.00215 seconds
Time Before: 0.03514 seconds
Time After: 0.04077 seconds
Time Taken: 0.00563 seconds
Time Before: 0.07596 seconds
Time After: 0.07625 seconds
Time Before: 0.09220 seconds
Time After: 0.09352 seconds
Time Taken: 0.00132 seconds
Time Before: 0.10373 seconds
Time After: 0.10393 seconds
Time Before: 0.10633 seconds
Time After: 0.10785 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=47017' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.12533 seconds
Time After: 0.12563 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
