Time Before: 0.00166 seconds
Time After: 0.00210 seconds
Time Before: 0.00216 seconds
Time After: 0.00256 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00356 seconds
Time After: 0.00628 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00297 seconds
Time After: 0.00965 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01138 seconds
Time After: 0.01176 seconds
Time Before: 0.01415 seconds
Time After: 0.01535 seconds
Time Before: 0.01078 seconds
Time After: 0.01552 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02306 seconds
Time After: 0.02329 seconds
Time Before: 0.02526 seconds
Time After: 0.02651 seconds
Time Before: 0.02941 seconds
Time After: 0.02954 seconds
Time Before: 0.03154 seconds
Time After: 0.03295 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=47081', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04516 seconds
Time After: 0.04539 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
