Time Before: 0.02292 seconds
Time After: 0.03092 seconds
Time Taken: 0.00801 seconds
Time Before: 0.03104 seconds
Time After: 0.03143 seconds
Time Before: 0.03167 seconds
Time After: 0.03182 seconds
Time Before: 0.03259 seconds
Time After: 0.03490 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03189 seconds
Time After: 0.03870 seconds
Time Taken: 0.00680 seconds
Time Before: 0.04450 seconds
Time After: 0.04489 seconds
Time Before: 0.04618 seconds
Time After: 0.04735 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04392 seconds
Time After: 0.04752 seconds
Time Taken: 0.00360 seconds
Memory After: 2,261.836 KB
Time Before: 0.08373 seconds
Time After: 0.08396 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09992 seconds
Time After: 0.10119 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10966 seconds
Time After: 0.10983 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11256 seconds
Time After: 0.11400 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789136976, location = '/forums/private.php?do=newpm&explain=1&u=47102' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.13388 seconds
Time After: 0.13419 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
