Time Before: 0.01691 seconds
Time After: 0.02341 seconds
Time Taken: 0.00650 seconds
Time Before: 0.02353 seconds
Time After: 0.02402 seconds
Time Before: 0.02435 seconds
Time After: 0.02451 seconds
Time Before: 0.02566 seconds
Time After: 0.02758 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02461 seconds
Time After: 0.03187 seconds
Time Taken: 0.00727 seconds
Time Before: 0.04076 seconds
Time After: 0.04117 seconds
Time Before: 0.04440 seconds
Time After: 0.04558 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03987 seconds
Time After: 0.04578 seconds
Time Taken: 0.00591 seconds
Time Before: 0.07675 seconds
Time After: 0.07690 seconds
Time Before: 0.08985 seconds
Time After: 0.09110 seconds
End call of global.php: 0.093172073364258
Time Before: 0.10251 seconds
Time After: 0.10267 seconds
Time Before: 0.10584 seconds
Time After: 0.10762 seconds
Time Taken: 0.00178 seconds
SET lastactivity = 1783078298, location = '/forums/private.php?do=newpm&explain=1&u=47114'
Time Before: 0.12636 seconds
Time After: 0.12678 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.12537908554077 seconds with 9 queries, spending 0.007927417755127 doing MySQL queries and 0.11745166778564 doing PHP things.
