Time Before: 0.01159 seconds
Time After: 0.01689 seconds
Time Taken: 0.00531 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01699 seconds
Time After: 0.01745 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01774 seconds
Time After: 0.01788 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01871 seconds
Time After: 0.02141 seconds
Time Taken: 0.00270 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01795 seconds
Time After: 0.02523 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.03210 seconds
Time After: 0.03248 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.03513 seconds
Time After: 0.03638 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.03148 seconds
Time After: 0.03659 seconds
Time Taken: 0.00512 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.05604 seconds
Time After: 0.05622 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.07297 seconds
Time After: 0.07422 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
End call of global.php: 0.076956987380981
Time Before: 0.08288 seconds
Time After: 0.08306 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.08574 seconds
Time After: 0.08721 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
SET lastactivity = 1785288134, location = '/forums/private.php?do=newpm&explain=1&u=47159'
Time Before: 0.10630 seconds
Time After: 0.10658 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
Page generated in 0.10529494285583 seconds with 9 queries, spending 0.0082762241363525 doing MySQL queries and 0.097018718719482 doing PHP things.
