Time Before: 0.01012 seconds
Time After: 0.01221 seconds
Time Taken: 0.00209 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01230 seconds
Time After: 0.01271 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01297 seconds
Time After: 0.01312 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01388 seconds
Time After: 0.01603 seconds
Time Taken: 0.00215 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01317 seconds
Time After: 0.02025 seconds
Time Taken: 0.00708 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02416 seconds
Time After: 0.02456 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02738 seconds
Time After: 0.02860 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.02347 seconds
Time After: 0.02886 seconds
Time Taken: 0.00539 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.05398 seconds
Time After: 0.05411 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.08362 seconds
Time After: 0.08494 seconds
Time Taken: 0.00132 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.087462186813354
Time Before: 0.10497 seconds
Time After: 0.10511 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.11004 seconds
Time After: 0.11169 seconds
Time Taken: 0.00164 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=47207', badlocation = 1
Time Before: 0.13787 seconds
Time After: 0.13809 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
Page generated in 0.13658809661865 seconds with 9 queries, spending 0.0077862739562988 doing MySQL queries and 0.12880182266235 doing PHP things.
