Time Before: 0.00152 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00289 seconds
Time Before: 0.00355 seconds
Time After: 0.00611 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00293 seconds
Time After: 0.00946 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01139 seconds
Time After: 0.01177 seconds
Time Before: 0.01470 seconds
Time After: 0.01595 seconds
Time Before: 0.01062 seconds
Time After: 0.01612 seconds
Time Taken: 0.00551 seconds
Time Before: 0.02140 seconds
Time After: 0.02155 seconds
Time Before: 0.02391 seconds
Time After: 0.02515 seconds
Time Before: 0.02871 seconds
Time After: 0.02886 seconds
Time Before: 0.03131 seconds
Time After: 0.03309 seconds
Time Taken: 0.00178 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=47219' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04792 seconds
Time After: 0.05119 seconds
Time Taken: 0.00327 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
