Time Before: 0.00134 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00238 seconds
Time Before: 0.00264 seconds
Time After: 0.00284 seconds
Time Before: 0.00346 seconds
Time After: 0.00565 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00288 seconds
Time After: 0.00912 seconds
Time Taken: 0.00624 seconds
Time Before: 0.01082 seconds
Time After: 0.01118 seconds
Time Before: 0.01358 seconds
Time After: 0.01502 seconds
Time Before: 0.01023 seconds
Time After: 0.01535 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02157 seconds
Time After: 0.02176 seconds
Time Before: 0.02376 seconds
Time After: 0.02526 seconds
Time Taken: 0.00150 seconds
Time Before: 0.02863 seconds
Time After: 0.02881 seconds
Time Before: 0.03076 seconds
Time After: 0.03221 seconds
UPDATE session SET lastactivity = 1785374695, location = '/forums/private.php?do=newpm&explain=1&u=47285', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04674 seconds
Time After: 0.04702 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
