Time Before: 0.00154 seconds
Time After: 0.00253 seconds
Time Taken: 0.00099 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00262 seconds
Time After: 0.00305 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00335 seconds
Time After: 0.00352 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00446 seconds
Time After: 0.00707 seconds
Time Taken: 0.00261 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00360 seconds
Time After: 0.01050 seconds
Time Taken: 0.00690 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01254 seconds
Time After: 0.01299 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01598 seconds
Time After: 0.01730 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01176 seconds
Time After: 0.01748 seconds
Time Taken: 0.00573 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02414 seconds
Time After: 0.02427 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02656 seconds
Time After: 0.02789 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
Time Before: 0.03194 seconds
Time After: 0.03209 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03491 seconds
Time After: 0.03670 seconds
Time Taken: 0.00180 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=47309' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05361 seconds
Time After: 0.05493 seconds
Memory Before: 4,919.109 KB
Memory After: 4,919.352 KB
