Time Before: 0.00138 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00233 seconds
Time Before: 0.00257 seconds
Time After: 0.00271 seconds
Time Before: 0.00364 seconds
Time After: 0.00625 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00278 seconds
Time After: 0.01183 seconds
Time Taken: 0.00904 seconds
Time Before: 0.01401 seconds
Time After: 0.01445 seconds
Time Before: 0.01761 seconds
Time After: 0.01882 seconds
Time Before: 0.01336 seconds
Time After: 0.01913 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02601 seconds
Time After: 0.02618 seconds
Time Before: 0.02829 seconds
Time After: 0.02950 seconds
End call of global.php: 0.031163930892944
Time Before: 0.03261 seconds
Time After: 0.03275 seconds
Time Before: 0.03548 seconds
Time After: 0.03690 seconds
SET lastactivity = 1788936198, location = '/forums/private.php?do=newpm&explain=1&u=47319'
Time Before: 0.05054 seconds
Time After: 0.05113 seconds
Time Taken: 0.00059 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049603939056396 seconds with 9 queries, spending 0.0083775520324707 doing MySQL queries and 0.041226387023926 doing PHP things.
