Time Before: 0.00193 seconds
Time After: 0.00249 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00256 seconds
Time After: 0.00300 seconds
Time Before: 0.00319 seconds
Time After: 0.00335 seconds
Time Before: 0.00404 seconds
Time After: 0.00731 seconds
Time Taken: 0.00327 seconds
Time Before: 0.00340 seconds
Time After: 0.01067 seconds
Time Taken: 0.00727 seconds
Time Before: 0.01274 seconds
Time After: 0.01313 seconds
Time Before: 0.01585 seconds
Time After: 0.01716 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01200 seconds
Time After: 0.01734 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02321 seconds
Time After: 0.02336 seconds
Time Before: 0.02546 seconds
Time After: 0.02675 seconds
End call of global.php: 0.028425931930542
Time Before: 0.02962 seconds
Time After: 0.02979 seconds
Time Before: 0.03170 seconds
Time After: 0.03317 seconds
SET lastactivity = 1782947978, location = '/forums/private.php?do=newpm&explain=1&u=47365'
Time Before: 0.04591 seconds
Time After: 0.04618 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.045015811920166 seconds with 9 queries, spending 0.0089221000671387 doing MySQL queries and 0.036093711853027 doing PHP things.
