Time Before: 0.00940 seconds
Time After: 0.01515 seconds
Time Taken: 0.00575 seconds
Time Before: 0.01526 seconds
Time After: 0.01585 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01605 seconds
Time After: 0.01615 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01683 seconds
Time After: 0.01939 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01620 seconds
Time After: 0.02278 seconds
Time Taken: 0.00658 seconds
Time Before: 0.02923 seconds
Time After: 0.02943 seconds
Time Before: 0.03194 seconds
Time After: 0.03322 seconds
Time Before: 0.02860 seconds
Time After: 0.03344 seconds
Time Taken: 0.00484 seconds
Time Before: 0.04726 seconds
Time After: 0.04739 seconds
Time Before: 0.05668 seconds
Time After: 0.05792 seconds
Time Before: 0.06305 seconds
Time After: 0.06320 seconds
Time Before: 0.06592 seconds
Time After: 0.06746 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1783369681, location = '/forums/private.php?do=newpm&explain=1&u=47420', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.08230 seconds
Time After: 0.08262 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
