Time Before: 0.00139 seconds
Time After: 0.00202 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00209 seconds
Time After: 0.00255 seconds
Time Before: 0.00276 seconds
Time After: 0.00295 seconds
Time Before: 0.00370 seconds
Time After: 0.00628 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00301 seconds
Time After: 0.00962 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01164 seconds
Time After: 0.01245 seconds
Time Taken: 0.00081 seconds
Time Before: 0.01547 seconds
Time After: 0.01676 seconds
Time Before: 0.01090 seconds
Time After: 0.01693 seconds
Time Taken: 0.00603 seconds
Time Before: 0.02211 seconds
Time After: 0.02229 seconds
Time Before: 0.02426 seconds
Time After: 0.02555 seconds
End call of global.php: 0.02717399597168
Time Before: 0.02857 seconds
Time After: 0.02875 seconds
Time Before: 0.03096 seconds
Time After: 0.03245 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=47456'
Time Before: 0.04569 seconds
Time After: 0.04595 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044770956039429 seconds with 9 queries, spending 0.0087213516235352 doing MySQL queries and 0.036049604415894 doing PHP things.
