Time Before: 0.00540 seconds
Time After: 0.00700 seconds
Time Taken: 0.00160 seconds
Time Before: 0.00708 seconds
Time After: 0.00752 seconds
Time Before: 0.00776 seconds
Time After: 0.00791 seconds
Time Before: 0.00866 seconds
Time After: 0.01083 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00797 seconds
Time After: 0.01516 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01881 seconds
Time After: 0.01919 seconds
Time Before: 0.02167 seconds
Time After: 0.02288 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01816 seconds
Time After: 0.02309 seconds
Time Taken: 0.00493 seconds
Memory After: 2,261.719 KB
Time Before: 0.03513 seconds
Time After: 0.03530 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.04174 seconds
Time After: 0.04319 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.045310974121094
Time Before: 0.04831 seconds
Time After: 0.04847 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.05115 seconds
Time After: 0.05260 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=47460'
Time Before: 0.07032 seconds
Time After: 0.07059 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.069278955459595 seconds with 9 queries, spending 0.0078232288360596 doing MySQL queries and 0.061455726623535 doing PHP things.
