Time Before: 0.01320 seconds
Time After: 0.02014 seconds
Time Taken: 0.00694 seconds
Time Before: 0.02026 seconds
Time After: 0.02077 seconds
Time Before: 0.02152 seconds
Time After: 0.02203 seconds
Time Before: 0.02291 seconds
Time After: 0.02484 seconds
Time Taken: 0.00193 seconds
Time Before: 0.02211 seconds
Time After: 0.02865 seconds
Time Taken: 0.00654 seconds
Time Before: 0.03597 seconds
Time After: 0.03633 seconds
Time Before: 0.03900 seconds
Time After: 0.04022 seconds
Time Before: 0.03540 seconds
Time After: 0.04047 seconds
Time Taken: 0.00507 seconds
Time Before: 0.06953 seconds
Time After: 0.06982 seconds
Time Before: 0.08935 seconds
Time After: 0.09059 seconds
Time Before: 0.10297 seconds
Time After: 0.10315 seconds
Time Before: 0.10618 seconds
Time After: 0.10767 seconds
UPDATE session SET lastactivity = 1788912483, location = '/forums/private.php?do=newpm&explain=1&u=47545' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.13265 seconds
Time After: 0.13290 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
