Time Before: 0.00144 seconds
Time After: 0.00188 seconds
Time Before: 0.00197 seconds
Time After: 0.00264 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00306 seconds
Time After: 0.00320 seconds
Time Before: 0.00389 seconds
Time After: 0.00774 seconds
Time Taken: 0.00385 seconds
Time Before: 0.00325 seconds
Time After: 0.01119 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01318 seconds
Time After: 0.01347 seconds
Time Before: 0.01585 seconds
Time After: 0.01727 seconds
Time Before: 0.01250 seconds
Time After: 0.01744 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02258 seconds
Time After: 0.02272 seconds
Time Before: 0.02480 seconds
Time After: 0.02608 seconds
End call of global.php: 0.027693033218384
Time Before: 0.02901 seconds
Time After: 0.02918 seconds
Time Before: 0.03132 seconds
Time After: 0.03274 seconds
SET lastactivity = 1785339838, location = '/forums/private.php?do=newpm&explain=1&u=47722', badlocation = 1
Time Before: 0.04748 seconds
Time After: 0.04781 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.046488046646118 seconds with 9 queries, spending 0.0097198486328125 doing MySQL queries and 0.036768198013306 doing PHP things.
