Time Before: 0.00970 seconds
Time After: 0.01181 seconds
Time Taken: 0.00211 seconds
Time Before: 0.01190 seconds
Time After: 0.01255 seconds
Time Taken: 0.00064 seconds
Time Before: 0.01283 seconds
Time After: 0.01300 seconds
Time Before: 0.01379 seconds
Time After: 0.01611 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01306 seconds
Time After: 0.02078 seconds
Time Taken: 0.00772 seconds
Time Before: 0.02535 seconds
Time After: 0.02576 seconds
Time Before: 0.02828 seconds
Time After: 0.02953 seconds
Time Before: 0.02458 seconds
Time After: 0.02973 seconds
Time Taken: 0.00515 seconds
Time Before: 0.04996 seconds
Time After: 0.05013 seconds
Memory Before: 3,438.242 KB
Memory After: 3,438.758 KB
Time Before: 0.05718 seconds
Time After: 0.05842 seconds
End call of global.php: 0.060541868209839
Time Before: 0.06462 seconds
Time After: 0.06482 seconds
Time Before: 0.06748 seconds
Time After: 0.06898 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=478', badlocation = 1
Time Before: 0.08592 seconds
Time After: 0.08625 seconds
Memory Before: 4,911.047 KB
Memory Used: 0.234 KB
Page generated in 0.084797859191895 seconds with 9 queries, spending 0.0082547664642334 doing MySQL queries and 0.076543092727661 doing PHP things.
