Time Before: 0.00174 seconds
Time After: 0.00219 seconds
Time Before: 0.00227 seconds
Time After: 0.00273 seconds
Time Before: 0.00297 seconds
Time After: 0.00324 seconds
Time Before: 0.00403 seconds
Time After: 0.00748 seconds
Time Taken: 0.00345 seconds
Time Before: 0.00331 seconds
Time After: 0.01258 seconds
Time Taken: 0.00927 seconds
Time Before: 0.01504 seconds
Time After: 0.01545 seconds
Time Before: 0.01819 seconds
Time After: 0.01947 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01436 seconds
Time After: 0.01976 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.836 KB
Time Before: 0.02839 seconds
Time After: 0.02855 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.03203 seconds
Time After: 0.03330 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03861 seconds
Time After: 0.03893 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.04232 seconds
Time After: 0.04511 seconds
Time Taken: 0.00280 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788961397, location = '/forums/private.php?do=newpm&explain=1&u=47821', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06428 seconds
Time After: 0.06480 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
