Time Before: 0.00138 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00248 seconds
Time Before: 0.00277 seconds
Time After: 0.00294 seconds
Time Before: 0.00380 seconds
Time After: 0.00634 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00304 seconds
Time After: 0.01137 seconds
Time Taken: 0.00833 seconds
Time Before: 0.01370 seconds
Time After: 0.01406 seconds
Time Before: 0.01612 seconds
Time After: 0.01740 seconds
Time Before: 0.01297 seconds
Time After: 0.01764 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02276 seconds
Time After: 0.02293 seconds
Time Before: 0.02507 seconds
Time After: 0.02636 seconds
End call of global.php: 0.029013872146606
Time Before: 0.03006 seconds
Time After: 0.03021 seconds
Time Before: 0.03222 seconds
Time After: 0.03366 seconds
SET lastactivity = 1789029176, location = '/forums/private.php?do=newpm&explain=1&u=47829'
Time Before: 0.05079 seconds
Time After: 0.05105 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049872875213623 seconds with 9 queries, spending 0.0081708431243896 doing MySQL queries and 0.041702032089233 doing PHP things.
