Time Before: 0.02967 seconds
Time After: 0.04009 seconds
Time Taken: 0.01042 seconds
Time Before: 0.04018 seconds
Time After: 0.04066 seconds
Time Before: 0.04089 seconds
Time After: 0.04102 seconds
Time Before: 0.04182 seconds
Time After: 0.04563 seconds
Time Taken: 0.00381 seconds
Time Before: 0.04109 seconds
Time After: 0.04925 seconds
Time Taken: 0.00816 seconds
Time Before: 0.05652 seconds
Time After: 0.05701 seconds
Time Before: 0.05844 seconds
Time After: 0.06062 seconds
Time Taken: 0.00218 seconds
Time Before: 0.05569 seconds
Time After: 0.06081 seconds
Time Taken: 0.00512 seconds
Time Before: 0.09306 seconds
Time After: 0.09319 seconds
Time Before: 0.12110 seconds
Time After: 0.12257 seconds
End call of global.php: 0.12546706199646
Time Before: 0.13593 seconds
Time After: 0.13611 seconds
Time Before: 0.13885 seconds
Time After: 0.14032 seconds
SET lastactivity = 1776558583, location = '/forums/private.php?do=newpm&explain=1&u=47836'
Time Before: 0.15925 seconds
Time After: 0.15951 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.15821814537048 seconds with 9 queries, spending 0.010602712631226 doing MySQL queries and 0.14761543273926 doing PHP things.
