Time Before: 0.00200 seconds
Time After: 0.00261 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00268 seconds
Time After: 0.00308 seconds
Time Before: 0.00329 seconds
Time After: 0.00347 seconds
Time Before: 0.00413 seconds
Time After: 0.00655 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00351 seconds
Time After: 0.01192 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01449 seconds
Time After: 0.01489 seconds
Time Before: 0.01769 seconds
Time After: 0.01888 seconds
Time Before: 0.01372 seconds
Time After: 0.01917 seconds
Time Taken: 0.00545 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.02738 seconds
Time After: 0.02755 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.03151 seconds
Time After: 0.03343 seconds
Time Taken: 0.00192 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
Time Before: 0.03807 seconds
Time After: 0.03821 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.04074 seconds
Time After: 0.04234 seconds
Time Taken: 0.00160 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
UPDATE session SET lastactivity = 1789070079, location = '/forums/private.php?do=newpm&explain=1&u=47855' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05729 seconds
Time After: 0.06021 seconds
Time Taken: 0.00291 seconds
Memory Before: 4,911.148 KB
Memory After: 4,911.375 KB
