Time Before: 0.00391 seconds
Time After: 0.00608 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00618 seconds
Time After: 0.00679 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00701 seconds
Time After: 0.00713 seconds
Time Before: 0.00806 seconds
Time After: 0.01169 seconds
Time Taken: 0.00363 seconds
Time Before: 0.00721 seconds
Time After: 0.01513 seconds
Time Taken: 0.00792 seconds
Time Before: 0.01873 seconds
Time After: 0.01916 seconds
Time Before: 0.02225 seconds
Time After: 0.02343 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01806 seconds
Time After: 0.02361 seconds
Time Taken: 0.00554 seconds
Memory After: 2,261.836 KB
Time Before: 0.03484 seconds
Time After: 0.03498 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"26.33,\";s:9:\"lastcheck\";i:1788847905;}', 1)
Time Before: 0.04089 seconds
Time After: 0.04150 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.04418 seconds
Time After: 0.04545 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
End call of global.php: 0.049057960510254
Time Before: 0.05133 seconds
Time After: 0.05151 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.05497 seconds
Time After: 0.05643 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
SET lastactivity = 1788847905, location = '/forums/private.php?do=newpm&explain=1&u=47907'
Time Before: 0.07139 seconds
Time After: 0.07166 seconds
Memory Before: 4,296.148 KB
Memory After: 4,296.375 KB
Page generated in 0.070425033569336 seconds with 10 queries, spending 0.0099079608917236 doing MySQL queries and 0.060517072677612 doing PHP things.
