Time Before: 0.01816 seconds
Time After: 0.02244 seconds
Time Taken: 0.00428 seconds
Time Before: 0.02255 seconds
Time After: 0.02312 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02343 seconds
Time After: 0.02359 seconds
Time Before: 0.02470 seconds
Time After: 0.02869 seconds
Time Taken: 0.00399 seconds
Time Before: 0.02367 seconds
Time After: 0.03290 seconds
Time Taken: 0.00923 seconds
Time Before: 0.04095 seconds
Time After: 0.04136 seconds
Time Before: 0.04374 seconds
Time After: 0.04509 seconds
Time Taken: 0.00135 seconds
Time Before: 0.04019 seconds
Time After: 0.04535 seconds
Time Taken: 0.00516 seconds
Time Before: 0.07428 seconds
Time After: 0.07446 seconds
Time Before: 0.09106 seconds
Time After: 0.09227 seconds
End call of global.php: 0.094314813613892
Time Before: 0.10240 seconds
Time After: 0.10258 seconds
Time Before: 0.10524 seconds
Time After: 0.10670 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=47918', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.12533 seconds
Time After: 0.13216 seconds
Time Taken: 0.00683 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.12432980537415 seconds with 9 queries, spending 0.016345024108887 doing MySQL queries and 0.10798478126526 doing PHP things.
