Time Before: 0.00178 seconds
Time After: 0.00244 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00254 seconds
Time After: 0.00292 seconds
Time Before: 0.00317 seconds
Time After: 0.00333 seconds
Time Before: 0.00427 seconds
Time After: 0.00679 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00341 seconds
Time After: 0.01022 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01212 seconds
Time After: 0.01249 seconds
Time Before: 0.01373 seconds
Time After: 0.01555 seconds
Time Taken: 0.00182 seconds
Time Before: 0.01153 seconds
Time After: 0.01580 seconds
Time Taken: 0.00427 seconds
Time Before: 0.02209 seconds
Time After: 0.02224 seconds
Time Before: 0.02433 seconds
Time After: 0.02561 seconds
Time Before: 0.02860 seconds
Time After: 0.02880 seconds
Time Before: 0.03152 seconds
Time After: 0.03297 seconds
UPDATE session SET lastactivity = 1776458395, location = '/forums/private.php?do=newpm&explain=1&u=47945', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.04566 seconds
Time After: 0.06443 seconds
Time Taken: 0.01878 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
