Time Before: 0.00145 seconds
Time After: 0.00195 seconds
Time Before: 0.00203 seconds
Time After: 0.00246 seconds
Time Before: 0.00271 seconds
Time After: 0.00288 seconds
Time Before: 0.00378 seconds
Time After: 0.00955 seconds
Time Taken: 0.00576 seconds
Time Before: 0.00295 seconds
Time After: 0.01456 seconds
Time Taken: 0.01161 seconds
Time Before: 0.01641 seconds
Time After: 0.01687 seconds
Time Before: 0.02098 seconds
Time After: 0.02292 seconds
Time Taken: 0.00195 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01577 seconds
Time After: 0.02317 seconds
Time Taken: 0.00739 seconds
Memory After: 2,261.719 KB
Time Before: 0.02962 seconds
Time After: 0.02977 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03247 seconds
Time After: 0.03463 seconds
Time Taken: 0.00215 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03762 seconds
Time After: 0.03777 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03989 seconds
Time After: 0.04172 seconds
Time Taken: 0.00182 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=47948' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05779 seconds
Time After: 0.05811 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
