Time Before: 0.02350 seconds
Time After: 0.03433 seconds
Time Taken: 0.01083 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03448 seconds
Time After: 0.03490 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03516 seconds
Time After: 0.03532 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03616 seconds
Time After: 0.03870 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03539 seconds
Time After: 0.04383 seconds
Time Taken: 0.00845 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05479 seconds
Time After: 0.05523 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05777 seconds
Time After: 0.05907 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05396 seconds
Time After: 0.05938 seconds
Time Taken: 0.00542 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.11191 seconds
Time After: 0.11209 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.18343 seconds
Time After: 0.18467 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.18709683418274
Time Before: 0.21201 seconds
Time After: 0.21221 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.21799 seconds
Time After: 0.21947 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772675269, location = '/forums/private.php?do=newpm&explain=1&u=48037'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.25143 seconds
Time After: 0.25169 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.25023293495178 seconds with 9 queries, spending 0.0082261562347412 doing MySQL queries and 0.24200677871704 doing PHP things.
