Time Before: 0.01666 seconds
Time After: 0.02075 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02086 seconds
Time After: 0.02139 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02169 seconds
Time After: 0.02188 seconds
Time Before: 0.02267 seconds
Time After: 0.02507 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02195 seconds
Time After: 0.02925 seconds
Time Taken: 0.00730 seconds
Time Before: 0.03705 seconds
Time After: 0.03748 seconds
Time Before: 0.04039 seconds
Time After: 0.04189 seconds
Time Taken: 0.00151 seconds
Time Before: 0.03568 seconds
Time After: 0.04217 seconds
Time Taken: 0.00650 seconds
Time Before: 0.07258 seconds
Time After: 0.07275 seconds
Time Before: 0.09144 seconds
Time After: 0.09272 seconds
Time Before: 0.10232 seconds
Time After: 0.10249 seconds
Time Before: 0.10562 seconds
Time After: 0.10713 seconds
UPDATE session SET lastactivity = 1783204208, location = '/forums/private.php?do=newpm&explain=1&u=48157' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.12560 seconds
Time After: 0.12586 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
