Time Before: 0.00152 seconds
Time After: 0.00204 seconds
Time Before: 0.00212 seconds
Time After: 0.00259 seconds
Time Before: 0.00285 seconds
Time After: 0.00296 seconds
Time Before: 0.00370 seconds
Time After: 0.00632 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00301 seconds
Time After: 0.00973 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01137 seconds
Time After: 0.01172 seconds
Time Before: 0.01407 seconds
Time After: 0.01531 seconds
Time Before: 0.01083 seconds
Time After: 0.01551 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02073 seconds
Time After: 0.02095 seconds
Time Before: 0.02302 seconds
Time After: 0.02427 seconds
Time Before: 0.02734 seconds
Time After: 0.02751 seconds
Time Before: 0.02952 seconds
Time After: 0.03094 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=48228' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04388 seconds
Time After: 0.04423 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
