Time Before: 0.01853 seconds
Time After: 0.02122 seconds
Time Taken: 0.00269 seconds
Time Before: 0.02135 seconds
Time After: 0.02190 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02221 seconds
Time After: 0.02236 seconds
Time Before: 0.02329 seconds
Time After: 0.02655 seconds
Time Taken: 0.00326 seconds
Time Before: 0.02243 seconds
Time After: 0.03079 seconds
Time Taken: 0.00836 seconds
Time Before: 0.03828 seconds
Time After: 0.03875 seconds
Time Before: 0.04240 seconds
Time After: 0.04366 seconds
Time Before: 0.03718 seconds
Time After: 0.04388 seconds
Time Taken: 0.00670 seconds
Time Before: 0.06809 seconds
Time After: 0.06824 seconds
Time Before: 0.08043 seconds
Time After: 0.08170 seconds
Time Before: 0.09033 seconds
Time After: 0.09050 seconds
Time Before: 0.09324 seconds
Time After: 0.09472 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=48242', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.11168 seconds
Time After: 0.11202 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
