Time Before: 0.00812 seconds
Time After: 0.01016 seconds
Time Taken: 0.00203 seconds
Time Before: 0.01026 seconds
Time After: 0.01065 seconds
Time Before: 0.01084 seconds
Time After: 0.01096 seconds
Time Before: 0.01179 seconds
Time After: 0.01473 seconds
Time Taken: 0.00294 seconds
Time Before: 0.01105 seconds
Time After: 0.01988 seconds
Time Taken: 0.00883 seconds
Time Before: 0.02476 seconds
Time After: 0.02515 seconds
Time Before: 0.02776 seconds
Time After: 0.02894 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02386 seconds
Time After: 0.02921 seconds
Time Taken: 0.00535 seconds
Time Before: 0.04729 seconds
Time After: 0.04744 seconds
Time Before: 0.05400 seconds
Time After: 0.05537 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.057635068893433
Time Before: 0.06075 seconds
Time After: 0.06090 seconds
Time Before: 0.06332 seconds
Time After: 0.06477 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=48273', badlocation = 1
Time Before: 0.08273 seconds
Time After: 0.08322 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.081646203994751 seconds with 9 queries, spending 0.0086266994476318 doing MySQL queries and 0.073019504547119 doing PHP things.
