Time Before: 0.00216 seconds
Time After: 0.00285 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00292 seconds
Time After: 0.00328 seconds
Time Before: 0.00345 seconds
Time After: 0.00354 seconds
Time Taken: 0.00009 seconds
Time Before: 0.00414 seconds
Time After: 0.00625 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00358 seconds
Time After: 0.00962 seconds
Time Taken: 0.00603 seconds
Time Before: 0.01140 seconds
Time After: 0.01155 seconds
Time Before: 0.01333 seconds
Time After: 0.01452 seconds
Time Before: 0.01087 seconds
Time After: 0.01474 seconds
Time Taken: 0.00387 seconds
Time Before: 0.02142 seconds
Time After: 0.02159 seconds
Time Before: 0.06904 seconds
Time After: 0.07029 seconds
End call of global.php: 0.072092056274414
Time Before: 0.07322 seconds
Time After: 0.07336 seconds
Time Before: 0.07538 seconds
Time After: 0.07692 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=48354', badlocation = 1
Time Before: 0.09272 seconds
Time After: 0.09301 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.091793060302734 seconds with 9 queries, spending 0.0073153972625732 doing MySQL queries and 0.084477663040161 doing PHP things.
