Time Before: 0.00207 seconds
Time After: 0.00265 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00272 seconds
Time After: 0.00310 seconds
Time Before: 0.00330 seconds
Time After: 0.00342 seconds
Time Before: 0.00414 seconds
Time After: 0.00620 seconds
Time Taken: 0.00205 seconds
Time Before: 0.00347 seconds
Time After: 0.01120 seconds
Time Taken: 0.00773 seconds
Time Before: 0.01354 seconds
Time After: 0.01399 seconds
Time Before: 0.01712 seconds
Time After: 0.01835 seconds
Time Before: 0.01284 seconds
Time After: 0.01866 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02617 seconds
Time After: 0.02632 seconds
Time Before: 0.02863 seconds
Time After: 0.02986 seconds
Time Before: 0.03322 seconds
Time After: 0.03337 seconds
Time Before: 0.03568 seconds
Time After: 0.03715 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=48369' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.05616 seconds
Time After: 0.05654 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
