Time Before: 0.00136 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00237 seconds
Time Before: 0.00263 seconds
Time After: 0.00276 seconds
Time Before: 0.00372 seconds
Time After: 0.00617 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00284 seconds
Time After: 0.00955 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01140 seconds
Time After: 0.01188 seconds
Time Before: 0.01472 seconds
Time After: 0.01594 seconds
Time Before: 0.01072 seconds
Time After: 0.01613 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02123 seconds
Time After: 0.02137 seconds
Time Before: 0.02341 seconds
Time After: 0.02465 seconds
Time Before: 0.02767 seconds
Time After: 0.02787 seconds
Time Before: 0.03018 seconds
Time After: 0.03163 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=48471' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04408 seconds
Time After: 0.04437 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
