Time Before: 0.02725 seconds
Time After: 0.03738 seconds
Time Taken: 0.01013 seconds
Time Before: 0.03750 seconds
Time After: 0.03809 seconds
Time Taken: 0.00059 seconds
Time Before: 0.03840 seconds
Time After: 0.03854 seconds
Time Before: 0.03944 seconds
Time After: 0.04216 seconds
Time Taken: 0.00272 seconds
Time Before: 0.03860 seconds
Time After: 0.04653 seconds
Time Taken: 0.00794 seconds
Time Before: 0.05788 seconds
Time After: 0.05825 seconds
Time Before: 0.06086 seconds
Time After: 0.06213 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05718 seconds
Time After: 0.06232 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.852 KB
Memory Used: 132.898 KB
Time Before: 0.10129 seconds
Time After: 0.10149 seconds
Memory Before: 2,815.430 KB
Memory After: 2,815.945 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"36.37,\";s:9:\"lastcheck\";i:1789124853;}', 1)
Time Before: 0.12033 seconds
Time After: 0.12097 seconds
Time Taken: 0.00064 seconds
Memory Before: 2,816.695 KB
Memory After: 2,816.945 KB
Memory Used: 0.250 KB
Time Before: 0.14197 seconds
Time After: 0.14323 seconds
Memory Before: 2,904.000 KB
Memory After: 2,904.594 KB
End call of global.php: 0.14615607261658
Time Before: 0.15455 seconds
Time After: 0.15476 seconds
Memory Before: 3,540.750 KB
Memory After: 3,541.180 KB
Time Before: 0.15867 seconds
Time After: 0.16018 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,822.281 KB
Memory After: 3,823.969 KB
SET lastactivity = 1789124853, location = '/forums/private.php?do=newpm&explain=1&u=48486'
Time Before: 0.18347 seconds
Time After: 0.18371 seconds
Memory Before: 4,296.172 KB
Memory After: 4,296.398 KB
Page generated in 0.18247389793396 seconds with 10 queries, spending 0.0091488361358643 doing MySQL queries and 0.1733250617981 doing PHP things.
