Time Before: 0.01460 seconds
Time After: 0.01943 seconds
Time Taken: 0.00483 seconds
Time Before: 0.01953 seconds
Time After: 0.02012 seconds
Time Taken: 0.00059 seconds
Time Before: 0.02043 seconds
Time After: 0.02059 seconds
Time Before: 0.02145 seconds
Time After: 0.02409 seconds
Time Taken: 0.00264 seconds
Time Before: 0.02066 seconds
Time After: 0.02887 seconds
Time Taken: 0.00821 seconds
Time Before: 0.03481 seconds
Time After: 0.03522 seconds
Time Before: 0.03774 seconds
Time After: 0.03893 seconds
Time Before: 0.03400 seconds
Time After: 0.03917 seconds
Time Taken: 0.00517 seconds
Time Before: 0.06551 seconds
Time After: 0.06567 seconds
Time Before: 0.07625 seconds
Time After: 0.07756 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.080450057983398
Time Before: 0.08519 seconds
Time After: 0.08536 seconds
Time Before: 0.08874 seconds
Time After: 0.09023 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=48494'
Time Before: 0.11244 seconds
Time After: 0.11284 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.11092209815979 seconds with 9 queries, spending 0.0085434913635254 doing MySQL queries and 0.10237860679626 doing PHP things.
