Time Before: 0.00143 seconds
Time After: 0.00199 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00205 seconds
Time After: 0.00245 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00267 seconds
Time After: 0.00279 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00362 seconds
Time After: 0.00630 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00286 seconds
Time After: 0.01016 seconds
Time Taken: 0.00729 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01205 seconds
Time After: 0.01241 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01490 seconds
Time After: 0.01608 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01150 seconds
Time After: 0.01628 seconds
Time Taken: 0.00477 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02209 seconds
Time After: 0.02227 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02457 seconds
Time After: 0.02580 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.027638912200928
Time Before: 0.02889 seconds
Time After: 0.02907 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03206 seconds
Time After: 0.03351 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=48517', badlocation = 1
Time Before: 0.04751 seconds
Time After: 0.04780 seconds
Memory Before: 4,918.633 KB
Memory After: 4,918.859 KB
Page generated in 0.046622037887573 seconds with 9 queries, spending 0.0080776214599609 doing MySQL queries and 0.038544416427612 doing PHP things.
