Time Before: 0.02035 seconds
Time After: 0.02469 seconds
Time Taken: 0.00434 seconds
Time Before: 0.02480 seconds
Time After: 0.02520 seconds
Time Before: 0.02543 seconds
Time After: 0.02558 seconds
Time Before: 0.02633 seconds
Time After: 0.02857 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02565 seconds
Time After: 0.03339 seconds
Time Taken: 0.00774 seconds
Time Before: 0.04661 seconds
Time After: 0.04701 seconds
Time Before: 0.04869 seconds
Time After: 0.04989 seconds
Time Before: 0.04583 seconds
Time After: 0.05016 seconds
Time Taken: 0.00433 seconds
Time Before: 0.08049 seconds
Time After: 0.08064 seconds
Time Before: 0.09679 seconds
Time After: 0.09807 seconds
Time Before: 0.10878 seconds
Time After: 0.10893 seconds
Time Before: 0.11106 seconds
Time After: 0.11249 seconds
UPDATE session SET lastactivity = 1784808872, location = '/forums/private.php?do=newpm&explain=1&u=48607' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.13017 seconds
Time After: 0.13046 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
