Time Before: 0.00841 seconds
Time After: 0.01094 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01106 seconds
Time After: 0.01152 seconds
Time Before: 0.01174 seconds
Time After: 0.01187 seconds
Time Before: 0.01270 seconds
Time After: 0.01490 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01193 seconds
Time After: 0.02016 seconds
Time Taken: 0.00823 seconds
Time Before: 0.02366 seconds
Time After: 0.02420 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02679 seconds
Time After: 0.02810 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02297 seconds
Time After: 0.02840 seconds
Time Taken: 0.00543 seconds
Time Before: 0.04072 seconds
Time After: 0.04090 seconds
Time Before: 0.04742 seconds
Time After: 0.04900 seconds
Time Taken: 0.00158 seconds
End call of global.php: 0.051095962524414
Time Before: 0.05449 seconds
Time After: 0.05462 seconds
Time Before: 0.05731 seconds
Time After: 0.05881 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=48716'
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.07607 seconds
Time After: 0.07638 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.074909925460815 seconds with 9 queries, spending 0.008338451385498 doing MySQL queries and 0.066571474075317 doing PHP things.
