Time Before: 0.00967 seconds
Time After: 0.01236 seconds
Time Taken: 0.00268 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01244 seconds
Time After: 0.01286 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01308 seconds
Time After: 0.01321 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01407 seconds
Time After: 0.01676 seconds
Time Taken: 0.00269 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01328 seconds
Time After: 0.02139 seconds
Time Taken: 0.00812 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02638 seconds
Time After: 0.02680 seconds
Time Before: 0.02945 seconds
Time After: 0.03067 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02573 seconds
Time After: 0.03089 seconds
Time Taken: 0.00516 seconds
Memory After: 2,261.703 KB
Time Before: 0.05027 seconds
Time After: 0.05043 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.05792 seconds
Time After: 0.05919 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.061573028564453
Time Before: 0.06438 seconds
Time After: 0.06464 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.06809 seconds
Time After: 0.06958 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=48756'
Time Before: 0.08796 seconds
Time After: 0.08827 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
Page generated in 0.086519002914429 seconds with 9 queries, spending 0.0083684921264648 doing MySQL queries and 0.078150510787964 doing PHP things.
