Time Before: 0.00197 seconds
Time After: 0.00282 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00290 seconds
Time After: 0.00341 seconds
Time Before: 0.00362 seconds
Time After: 0.00375 seconds
Time Before: 0.00447 seconds
Time After: 0.00704 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00380 seconds
Time After: 0.01247 seconds
Time Taken: 0.00867 seconds
Time Before: 0.01524 seconds
Time After: 0.01567 seconds
Time Before: 0.01725 seconds
Time After: 0.01862 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01422 seconds
Time After: 0.01887 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02652 seconds
Time After: 0.02679 seconds
Time Before: 0.02962 seconds
Time After: 0.03111 seconds
Time Taken: 0.00150 seconds
Time Before: 0.03534 seconds
Time After: 0.03551 seconds
Time Before: 0.03852 seconds
Time After: 0.04002 seconds
UPDATE session SET lastactivity = 1788896037, location = '/forums/private.php?do=newpm&explain=1&u=48797', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05383 seconds
Time After: 0.05413 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
