Time Before: 0.00139 seconds
Time After: 0.00189 seconds
Time Before: 0.00199 seconds
Time After: 0.00262 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00283 seconds
Time After: 0.00294 seconds
Time Before: 0.00363 seconds
Time After: 0.00586 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00299 seconds
Time After: 0.00946 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01125 seconds
Time After: 0.01172 seconds
Time Before: 0.01450 seconds
Time After: 0.01573 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01065 seconds
Time After: 0.01590 seconds
Time Taken: 0.00525 seconds
Memory After: 2,261.836 KB
Time Before: 0.02081 seconds
Time After: 0.02092 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02279 seconds
Time After: 0.02401 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.02679 seconds
Time After: 0.02693 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.02880 seconds
Time After: 0.03023 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788905987, location = '/forums/private.php?do=newpm&explain=1&u=48824' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04241 seconds
Time After: 0.04271 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
