Time Before: 0.00494 seconds
Time After: 0.00688 seconds
Time Taken: 0.00194 seconds
Time Before: 0.00695 seconds
Time After: 0.00737 seconds
Time Before: 0.00763 seconds
Time After: 0.00777 seconds
Time Before: 0.00845 seconds
Time After: 0.01090 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00782 seconds
Time After: 0.01426 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01708 seconds
Time After: 0.01749 seconds
Time Before: 0.02020 seconds
Time After: 0.02147 seconds
Time Before: 0.01631 seconds
Time After: 0.02175 seconds
Time Taken: 0.00544 seconds
Time Before: 0.03270 seconds
Time After: 0.03285 seconds
Time Before: 0.03910 seconds
Time After: 0.04038 seconds
Time Before: 0.04485 seconds
Time After: 0.04504 seconds
Time Before: 0.04804 seconds
Time After: 0.04952 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=4895', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.06269 seconds
Time After: 0.06298 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
