Time Before: 0.01917 seconds
Time After: 0.02671 seconds
Time Taken: 0.00754 seconds
Time Before: 0.02683 seconds
Time After: 0.02727 seconds
Time Before: 0.02753 seconds
Time After: 0.02768 seconds
Time Before: 0.02863 seconds
Time After: 0.03099 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02778 seconds
Time After: 0.03532 seconds
Time Before: 0.04562 seconds
Time After: 0.04601 seconds
Time Before: 0.04925 seconds
Time After: 0.05043 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04490 seconds
Time After: 0.05064 seconds
Time Taken: 0.00573 seconds
Time Before: 0.09655 seconds
Time After: 0.09670 seconds
Time Before: 0.18098 seconds
Time After: 0.18225 seconds
End call of global.php: 0.18450999259949
Time Before: 0.19402 seconds
Time After: 0.19420 seconds
Time Before: 0.19709 seconds
Time After: 0.19852 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=48961', badlocation = 1
Time Before: 0.21919 seconds
Time After: 0.21946 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.21806383132935 seconds with 9 queries, spending 0.0078399181365967 doing MySQL queries and 0.21022391319275 doing PHP things.
